Retorque head
Will
12-11-2003 07:08:08
After you install a head you should retorque the nuts after running the tractor for a while, right? Should this be done while hot or after it cools, or both?
John Saeli
12-11-2003 08:06:19
 Re: Retorque head in reply to Will, 12-11-2003 07:08:08
Hey Men; I believe it's very critical to retorque all heads, even if the gasket says not needed. The reason is that I have always gained threads. Retorque hot. Back head bolt or nut off 90 degrees, then come back up to torque specs. one at a time in proper pattern. I always lube the threads before installation. Good luck.
RobertTX
12-11-2003 07:54:37
The factory manual for my 500 Diesel says retorque hot. I don't remember what it says on the LAs, they are not as critical.
Dr Cy Kosis
12-12-2003 11:50:49
 Re: Re: Retorque head in reply to RobertTX, 12-11-2003 07:54:37
Robert,
Nice to see you're still amoung the living. Last time I spoke with you you were under the weather a bit.
I have a trek coming up over the holidays that will take me near Houston. Me and "The Great Mike Schotte" were thinking about dropping by to see your collection if you were going to be around. He's gripping to see that 500 of yours. I also can deliver your LA tank while I'm at it.
I have off from the 20th to the 4th this year so it will be somewhere in that time frame, probably after the 26th at the soonest.
I'll get back with you as it gets closer.
RobertTX
12-12-2003 12:46:08
 Re: Re: Re: Retorque head in reply to Dr Cy Kosis, 12-12-2003 11:50:49
Dr.,
Sounds great, I'll be there. I have the week of Christmas off, also some days around New Year. Email (in Case you lost it):
[email protected]
