can you help me find info on my Case backhoe?
Doug Foster
12-10-2003 15:23:19
I recently purchased a good cond. case backhoe its a diesel motor standard trans only 2 wheel drive orange motor and yellow body parts (repainted) under the new paint I can read case 530 on the hoe arm and on the loader is a tag reading Model 31 #4077174 can anyone tell me the year? or anything else about this tractor? I paid 3,500 for it and it only needed a few hoses and front wheel bearings, did i do o.k.? it also has front wheel weights and a large weight off the front no pto shaft off the rear just a blank plate but has a hydrolic pump just in front of the radiator. Thanks Doug
Steve Schmittgens
12-15-2003 13:32:08
 Re: can you help me find info on my Case backhoe? in reply to Doug Foster, 12-10-2003 15:23:19
Doug,
Case 530's with the model 31 loader & hoe were the early to mid '60's. If they were loader\backhoes they were 530SL. If you could find the machine serial No. I might be able to get you an exact year of manufacture.
Steve
DaleIN
12-11-2003 09:55:42
Doug, it appears to be a 1963. Case put 31 loaders and hoes on the 530 ag and utility tractors. Its probably not worth quite as much as its 530 Construction King cousin with the 32 ldr/hoe, but that doesn't seem too far out of line on price to me. Hope this helps, Dale
