DC4 Hydraulic Filter - where can I get one?
Chris
12-09-2003 18:16:01
Can someone give me a good source to purchase replacement filters for my '53 DC4? I looked at the YT parts and couldn't find any filters. Any advice? Anybody got a part number? Thanks!!!
John Saeli
12-10-2003 04:29:36
 Re: DC4 Hydraulic Filter - where can I get one? in reply to Chris, 12-09-2003 18:16:01
Hey Chris; If your CASE dealer is anything at all, they should stock the oil filter: O8926AB. The Hyd. filter is washable, reuseable. NAPA is able to get the oil filter.
Paul f
12-10-2003 05:41:01
 Re: Re: DC4 Hydraulic Filter - where can I get one in reply to John Saeli, 12-10-2003 04:29:36
John: Are you sure about that part number... The manual for my DC3 (dual hydraulics) shows O8755AB (new A27460) for the filter. That is what I got from case and it fit...
Also Chris you will probably need a new filter cover gasket A27380 (About $4.50 from case)
paul f
John Saeli
12-10-2003 06:55:27
 Re: Re: Re: DC4 Hydraulic Filter - where can I get in reply to Paul f, 12-10-2003 05:41:01
Hey Paul; I screwed up. I misread the post. The O8926AB is the # for the engine oil filter.
Chris
12-10-2003 05:59:55
Paul,
Thanks for the tip. My gasket was so damaged that I didn't even realize there was a gasket there... I've ordered a new filter and gasket from a dealer I found not too far away.
Chris
12-10-2003 05:14:13
Thanks, I had no problem getting an oil filter. My hydraulic filter has to be replaced, when I removed it to clean it, I found it was damaged (exploded...) -- I don't think the hydraulic oil had been changed in many years... I'll look for a Case dealer to find a replacement. Thanks for the advice!
