case 188 gas engine
Philcase55inWPa
12-09-2003 06:09:56
I have been looking for an engine for my Case 641 (threw a rod & broken block) and may have leads to several now. Can anyone tell me where the casting number for the block on a 188 cu inch gas engine is located? My old engine has CWC and | 28 | on the side just above and to the left of the distributor. Is this the casting number? These are the only casting marks I can see with the engine still in the tractor. The serial number plate on the bottom of the engine is 2003506.
And while I'm asking, some people have told me to switch it to a diesel. I like diesels for a lot of reasons but is this feasable or economically reasonable on this tractor. I don't care particularly about being "original". Just want to get it back to work before spring. Or should I just scrap it and buy another tractor.
mike
12-09-2003 16:43:35
 Re: case 188 gas engine in reply to Philcase55inWPa, 12-09-2003 06:09:56
I have a 188 with a fresh head, good running engine.Email me if interested;.click on name.
I'am in Va.
Philcase55
12-10-2003 06:44:02
 Re: Re: case 188 gas engine in reply to mike, 12-09-2003 16:43:35
Mike, your name didn't pop up my email program. You must have the hide email button checked. But I am interested in the engine. Where are you located in VA. My brother in law is in the Harrisonburg area. How much do you want for the engine? Either emil me or respond in this forum.
Thanks.
Phil
[email protected]
K-Mo
12-09-2003 11:15:09
I put a combine engine in my 630. The only difference is the dip stick ended up on the opposite side. I was told it came from a Model 660 combone.
K-Mo
dctom
12-09-2003 17:03:26
 Re: Re: case 188 gas engine in reply to K-Mo, 12-09-2003 11:15:09
660 combine had 201 engine
mike
12-10-2003 17:29:18
 Re: Re: Re: case 188 gas engine in reply to dctom, 12-09-2003 17:03:26
The 600 case combine had a 188.
JCmarleau
12-09-2003 09:49:00
Where are you from, i have such an engine ready to go my e mail is [email protected]
Philcase55inWPa
12-09-2003 10:30:21
 Re: Re: case 188 gas engine in reply to JCmarleau, 12-09-2003 09:49:00
I am in Western Pennsylvania, about 30 miles north of Pittsburgh. Where are you located and how much do you want for the engine?
