CAse Tractor-need model #
Joe
12-08-2003 23:26:43
I bought a CASE tractor. it is Gas engine, 4cyl, and motor number is 73E11412.
I could not readily locate an Identification plate as yet.
It is missing the Head, and Carburator. I need to identify the year and model number to find the parts to get it running. Any help would be appreciated. thanks, Joe
Joe (Wa)
12-10-2003 12:27:59
 Re: CAse Tractor-need model # in reply to Joe, 12-08-2003 23:26:43
Engine serial nrs are only good for identifing a part that was changed within the type & sequence of the engine.
The 73 indicates the type of engine I.E. a Rock Island built VTA-1073 engine assembly. The E is the sequence. The 5 digits are the number of your specific engine.
72 & 73 appear to be common to the 50's VA series so like John said check the the photo section for a like model.
I would start with the VA series (VAC, VAI, VAO, ETC). Once you find the model, narrow down the year by general appearance, sheet metal, steering linkage, attachments, etc.
Joe
John H-WI
12-09-2003 17:22:57
Color of the tractor would help some. Or go to the tractor photos and do a search on Case and scan down and see what resembles yours.
