Clutch sticking on 400
martin in De.
12-07-2003 17:34:57
Having a problem with the clutch sticking,even after the tractor has been ran for a while. Once the clutch has been fully engaged it will not release.Is there a quick fix or will I need to split the tractor. Thanks Martin
C. Amick
12-08-2003 09:16:47
 Re: Clutch sticking on 400 in reply to martin in De., 12-07-2003 17:34:57
Sounds like the clutch may be adjusted too tight. Pull the side plate off and see if spinning the adjuster plate helps. You might want to make sure it is oiling properly while you have the plate off. When you park the tractor you should always disengage the clutch.
