Case CC Serial Number: What Year?
Texas Tradition
12-07-2003 17:22:45
Just got through looking at a CC with cutoffs on the rear. Real clean tractor. Motor is stuck. Rest looks real good. The serial # is C-3109490 on the tool box plate. I looked at the serial #"s on this site and can't figure out what year it is? Any help would be appreciated? Thanks Texas Tradition
Dr Cy Kosis
12-07-2003 18:03:16
 Re: Case CC Serial Number: What Year? in reply to Texas Tradition, 12-07-2003 17:22:45
1936
Seven digits starting less than 42 use the six digit formula.
1st and fourth minus 3
C-3xx9xxx = 39-3= 1936
Texas Tradition
12-07-2003 18:31:45
 Re: Re: Case CC Serial Number: What Year? in reply to Dr Cy Kosis, 12-07-2003 18:03:16
Doc: Thank you for the quick reply! Talked to a friend of mine awhile ago and he knows where there are a couple on steel and with wide front ends!!!! Looks like i'll be getting a nice CC for the next show year. Thanks Texas Tradition
Dr Cy Kosis
12-07-2003 18:41:13
 Re: Re: Re: Case CC Serial Number: What Year? in reply to Texas Tradition, 12-07-2003 18:31:45
What part of my great Lone Star state are you in?
Check the other ones out. With wide fronts,they could either be "C"s or "CC4"s.
A C is a wheatland and will have slightly smaller diameter wider rear wheels and wider fenders that aren't as tall.
A CC4 will have taller narrower wheels, taller narrower fenders, differential brakes and there should be a lift block in between the front axle and the bolster to raise the front up level with the back.
Texaas Tradition
12-08-2003 16:09:37
 Re: Re: Re: Re: Case CC Serial Number: What Year? in reply to Dr Cy Kosis, 12-07-2003 18:41:13
Doc; I live south of San Antonio @40 miles. South of Floresville. I talked to my buddy about the other tractors, and there is one C or CC parts tractor. Serial # C-337347. Wide steel front, but no rear steel. The other tractor is a 1938 RC. The 3rd tractor is a 1949 SC. The tractor i looked at yesterday has some kind of wheel extensions on the back axle. Wierd looking. Thanks Texas Tradition
Dr Cy Kosis
12-08-2003 17:52:27
 Re: Re: Re: Re: Re: Case CC Serial Number: What Ye in reply to Texaas Tradition, 12-08-2003 16:09:37
C 337347 should be a 1930 model.
I'm about 250 miles due north of you up Hwy 281.
The RCs are a bit rarer than the Cs, CCs L's and such. Is the RC unstyled? I'm thinking a '38 would be. If you wind up with the RC, I know wheres theres a almost complete, but somewhat rough '36 RC for parts near me.
Tom Railsback
12-07-2003 19:31:38
Thee is the small possibility they could be CC3's with wide adjustable front ends too. I know they built some because I saw one at Rollag in 1992.
Dr Cy Kosis
12-07-2003 19:40:19
 Re: Re: Re: Re: Re: Case CC Serial Number: What Ye in reply to Tom Railsback, 12-07-2003 19:31:38
Thats something I've wondered about. I've never seen anything concrete about a CC3, just rumours so far.
