Was this a Mistake?
Powershift
12-07-2003 09:28:35
I just bought a 1974 Case 2470. The tractor has 6200 Hrs w/ 455 hrs. on a complete OH. It has 23.1*34 duals and appears to be in good condition. The tractor runs and drives very well. I am new to the Case 4 Wheelers. Are they a good tractor or did I make a mistake in buying one. Are there any weakness that I need to pay special attention to on these tractors? Thanks for any advice.
Jim B.
12-10-2003 18:08:38
 Re: Was this a Mistake? in reply to Powershift, 12-07-2003 09:28:35
I also have a 2470 that I feel is a great machine. The "Traction King" name is quite accurate. I also pull a 24' disk with that traction but not very fast with only 165 HP, only 4+MPH. A personally found problem with the 504 engine is the front damper/pulley on the crankshaft! The service manual, on page 2002-4, first item under Tune-Up Procedure, states that the pulley assembly should be REPLACED every 2000 engine hours. The Operators manual says nothing about this > even in the 'preventive maintenance' section. Cost of the Pulley: over $550. Cost of repairing the crankshaft when the pulley becomes loose: $700 + plus cost of labor & parts to remove engine to remove crank and then reassemble. Total is unacceptable when downtime is also considered. Who ever heard of checking the torque of the attaching bolt every couple of tanks of fuel ??? Bad design I'd say. So > check that bolt if you can find the right tools that will clear the radiator and AC setup.
JCmarleau
12-07-2003 18:51:16
If ever interested i have either a service or operator or parts manual for this unit my e mail is [email protected]
Jim Handke
12-07-2003 11:11:11
I have two of those tractors, both closing in on 7000 hours, and they're as tough as nails. My best one starts at 32 degrees with no ether. The trouble starts because of age. I have been replacing steel lines with hyd. hoses made at NAPA, cheaper than buying lines from Case. It's also easier to route them around the original plumbing. If you loose a u-joint in either driveline, take the whole joint to NAPA. They can measure it and find one that fits a semi, again cheaper than Case. Or if I can find my spare, I can get you the NAPA number. I have never had trouble with the u-joints that drive the planateries, although I've had to replace the bushings and seals in the axle housings. I need to work on both castings the rear axle pivots in. They're worn egg shaped, and when you get a rough shift, you can hear the clunk and feel the platform raise a little. I couldn't believe how much more we could do with these tractors. I've pulled a 24' disk and harrow uphill through wet spots that the tractor and planter can't go through on the level. Dad has never appreciated the times he's buried that rig because I told him I though he could make it. But that's another story. Let me know if you have any more questions, be more than glad to help.
Powershift
12-07-2003 18:06:02
 Re: Re: Was this a Mistake? in reply to Jim Handke, 12-07-2003 11:11:11
Jim, do you have any experience with the rear steering/crab steer on these tractors? What do the different positions on the lever in the cab mean? Mine is in automatic right now and it seems like when I turn the wheels all the way one way or the other the back wheels only turn a little bit, while the front wheels are turned all the way. Is this supposed to work like this?
Jim Handke
12-08-2003 05:57:00
 Re: Re: Re: Was this a Mistake? in reply to Powershift, 12-07-2003 18:06:02
On mine, the rears don't steer quite as sharp as the fronts. Cramp the wheels and turn one way for a couple of turns, and then check if the stop on the rear hub is hitting whatever it's supposed to. Then check the other way. I've never adjusted mine, even though we have a Case book that tells us how. If yours needs adjusting, let me know and I'll send you instructions.
Powershift
12-08-2003 12:06:16
 Re: Re: Re: Re: Was this a Mistake? in reply to Jim Handke, 12-08-2003 05:57:00
Jim, what book do you have? I have the operators manual and it tells nothing about how to adjust it. If you have any instructions on how to adjust it please let me know. Thanks for your help.
John Saeli
12-07-2003 09:54:58
Hey Powershift; If thats the 1 that just sold on Ebay, and it sounds like it is, you should have trouble sleeping nites. As far as I could tell, if the description is honest, that was a steal. Good luck with it.
