case vac?govenor problem I think
pat,maplehillfrm
12-07-2003 05:56:02
hello guys , I have what I was told is a case vac , It has a wide front end, but has no tags to identify, this came with a front mounted snow plow, not original to it but works good, my question is this, I have it running good starts in 2 revolutions, runs smooth, but the throttle control does not rev it up enough, I have tried to adjust the rod that is on the carb side,it comes from the govenor rod?, butit seems to just allow it to rev way hi without any control from the throttle control, I have pushed on the rod that goes to the govenor on the opposite side,{right side}and it seems to pick up speed but does not seem to be full,, I have used it yesterday to plow as we got a foot of snow, what I did was adjust the rod from the carb to the govenor shaft?- and it picked up the revs but it had to stay there , there was no control of the speed of the engine at all, the carb will go through speeds no problem with out the rod hooked{manually} is there a adjust ment I am missing or is teh govenor shot? thanks sorry for the long post pat
Rigidharley
12-10-2003 08:21:21
 Re: case vac?govenor problem I think in reply to pat,maplehillfrm, 12-07-2003 05:56:02
Hello, Have you tested your governor? heres how to do it.It will take 2 people. with motor off take hold of the governor rod on right side just in front of the hydraulic pump, make sure it moves back and forth freely. using one finger easily pull the rod were the spring is attached toward the rear of tractor, have your assistant start the engine,WATCH THE FAN BLADES, when the engine starts you should feel the governor pull the rod towards the radiator, if not, have your assistant speed the engine up a little,this works a lot better if you disconnect the rod on the carburator.If You feel the governor pull your finger then your problem is external,hopefully it's the carb rod,If this works or even does'nt work and you have a question feel free to Email me. at [email protected] Jim Edmonds
Jerry
12-07-2003 17:29:55
Pat , you may also find that the saucer has come off the shaft,causing the problem, it happened to dads vac.
Jerry
R. G. Maynard
12-07-2003 13:33:13
I have the same problem, hope someone comes thru with a easy fix. Will watch for a solition.
dctom
12-07-2003 14:09:18
 Re: Re: case vac?govenor problem I think in reply to R. G. Maynard, 12-07-2003 13:33:13
that governor is like two sausers togeather with balls held by a divider, sometines the balls get wore flat spots on them or the whole thing gets gummed up it also has a pin that slides in the end of the cam shaft and if that is gummed up and wont slide governor wont work tom
R.G.Maynard
12-09-2003 07:09:17
 Re: Re: Re: case vac?govenor problem I think in reply to dctom, 12-07-2003 14:09:18
The old style used the ball bearings and the new style uses the two weights. Is the new style better than the old, I have both with the old one in the tractor. What do you all think should I change out the govnor?
pat
12-07-2003 16:21:18
thansk maybe I will take the govenor off, and see what it looks like, am I opening a can of worms or are there parts available, thanks pat
Rc
12-07-2003 19:37:11
 Re: Re: Re: Re: case vac?govenor problem I think in reply to pat, 12-07-2003 16:21:18
On mine there was no in between it was all or nothing. I tried strething the spring now it wont open up so Ithink its the wrong spring. Rc
