combine engine for DC TOM
bill wilson
12-06-2003 20:32:33
Tom could you check #5303519D which is the combine engine I told you about You may have read I found 3�� alumium pistons and plated valve springs Looking at paint on engine and head gasket edge the head has never been off Thanks Bill
dctom
12-07-2003 07:23:54
 Re: combine engine for DC TOM in reply to bill wilson, 12-06-2003 20:32:33
sure your yard stick didnt slip, all D series engines were 3 7/8 top of the piston may be 3 3/4 but bore would be 3 7/8, and most all combine engines were alumin pistons and governed to 1400,
5303519 wqas built nov 12 1948 and shepped to bettendorf combine plant nov 13 1948
bill
12-07-2003 09:27:25
 Re: Re: combine engine for DC TOM in reply to dctom, 12-07-2003 07:23:54
RIGHT YARD STICK DID NOT SLIP BRAIN FADED WHEN TYPING WHEN DID CONBINES GO TO 4 INCH??? I HAD THOUGHT THE TAG WOULD HAVE DE OR SOMETHING OTHER THAN JUST D AS IN A D SERIES TRACTOR
dctom
12-07-2003 11:20:23
 Re: Re: Re: combine engine for DC TOM in reply to bill, 12-07-2003 09:27:25
maybe it ws built on monday morning, guy with a hangover didnt stamp it was the tag on the valve cover? accordubg to the book they had 4 inch peistons and 5505 hesad in 1942
bill
12-07-2003 11:48:17
 Re: Re: Re: Re: combine engine for DC TOM in reply to dctom, 12-07-2003 11:20:23
YEP TAG ON VALVE COVER AND THANKS FOR TAKING TIME TO LOOK UP I AM REASONBABLY HEAD HAS NEVER BEEN OFF AND HAS 5576A ALSO WHAT ABOUT THOSE PLATED VALVE SPRINGS HEAVER BECAUSE OF HIGHER RPM????? ?
