Was the SC as good as the DC?
Wide Open
12-06-2003 18:55:31
I seem to see alot more DC's still working than I do SC's. In my area for every SC I see working, I see 20 DC's. Was the SC built any less durable than the DC? Does a SC have any weak points?
cb
12-08-2003 06:49:56
 Re: Was the SC as good as the DC? in reply to Wide Open, 12-06-2003 18:55:31
My Dad sold DC's and and SC's in the 50's said that that the SC was more prone to valve problems than a DC.
"If you worked them hard" His quote.
To work a tractor "hard" was to turn them up for the most power and have them pull tillage tools about 20 hours per day and generally just beat the heck out it.
John H-WI
12-07-2003 15:49:09
The biggest fault with the DC was that it gulped a lot more gas than the SC. The SC is/was a very economic tractor to run. Out of all the SC's we had on the farm we only overhauled 1. We never touched the brakes on any of them or the DC's either. The only brake problems occured was with the CC if you had to stop on the hill. Going backwards it sucked. The 730 had a problem with the right brake. Oh, when it come to farming the VAC wasn't near the SC. There was no place it would ever pull 2 14's on the farms. Good little tractor for cultivating, mowing, raking hay, and other chores.
Glenn FitzGerald
12-07-2003 13:47:02
I've often wondered tht too as we have only had experience with DC's. But the way I figure it, any tractor that is so plentiful and being used so broadly 50 years after the last one was produced must be a good tractor. I've been told by the experts on this post the two compare quite like the H and M Farmall. Glenn Fitz
dctom
12-07-2003 14:11:53
 Re: Re: Was the SC as good as the DC? in reply to Glenn FitzGerald, 12-07-2003 13:47:02
yes that is right only the SC &DC were a notch ahead of the H &M till M&W make all thoes improvements for them tom
dctom
12-07-2003 11:22:24
SC just as tough as a DC only less hp
ff316
12-06-2003 20:35:41
I think it's more about value than quality. The DC was not a whole lot more expensive but was much more capable. The VAC was smaller but it is my understanding that the VAC was about as capable as the SC in most conditions. I saw an ad that listed the VAC as a two plow tractor in most conditions, and the SC as a two plow tractor in virtually all conditions. I like SC's though and wish I had not sold mine.
Fireman in KY
Jim Handke
12-07-2003 11:16:22
 Re: Re: Was the SC as good as the DC? in reply to ff316, 12-06-2003 20:35:41
The same thing happened with the 70 series tractors. My cousin was a dealer, and he could sell a 1370 for only $3000 more than a 1070. Needless to say, he moved very few 9/1070's.
