Block repair
Bill
12-06-2003 18:32:17
Need some suggestions on how to repair cracks between sleeves on a s c case. this is on the top of the block between #2 cyl and one between #3and 4. Can be drilled out some and welded? thanks for your help.
Elliott from ILL
12-07-2003 10:42:33
 Re: Block repair in reply to Bill, 12-06-2003 18:32:17
Thats right John. I have done that with J B Weld and it did work. Thats all I would do. Just make sure you don't have it too high on there. Elliott
John Saeli
12-07-2003 10:06:36
Hey Bill; I've gotten pounded on this before, but if it were mine, I wouldn't lose sleep over it. There is no combustion out there. It's sealed by the head gasket. If were mine, I would clean it good and fill it with JB Weld. Sand it back down. Good Luck.
Ted
12-07-2003 06:13:09
Bill, I don't know anything about this but it was posted a couple of days ago:
Posted by INCase on December 04, 2003 at 13:09:37 from (12.15.91.101):
FYI>...
found this web page thought a few of yous may be interested Link a bit high $$ though... $8/rod. claims to weld anything even castiron manifolds...
