D series conbine engine
bill
12-06-2003 11:41:12
I bought a D seres combine engine #5303519D Naturally the owner HAD to tur it ove to show it was not stuck so have a couple of bent push rods but valves loosened up of with oil I drained oil (no water) ha no filter so sludge in bottm bet lookes good Here the different part It has 3�� pistons ALUMINUM has 1400 rpm printed on combine drive housing and a plated heaver loking valve spring It has radiator but not same as D or DC Air cleaner is on side and manifold air parts have never been used I plan to start it and check our and put in my foot clutch DC which has broken block (dur to toomuch loader in the woods) If some one is into D type stationary engines i would sell radiator and drive housing I AM keeping the mag drive hyd pump Or if any body want to trade good D DC motor I would consider a trade Head is 5576A
