The joys of winter
Robert P
12-05-2003 13:35:31
Up here in Quebec cold weather is back. Woke this morning it was 5 deg F and the tractor would not move. Silly me I didn't check the transmission-differential fluid on my VAC. You know the answer... frozen stiff because water got in there. The poor thing is sitting outside and I'm melting the ice with a welding iron stuffed in the dip stick hole. Question ? Once I have drained the water/oil mixture can I replace it with grade 90 oil or should I clean the casing before. What is the proper way to do things ?
