Case identification #'s?
Mike Watson
06-02-1999 07:47:40
Have an old Case tractor that belonged to my grandfather. Since I can remember he has always said it was a 1955. My uncle seems to thing it is an older tractor. Me too. Only has 4 forward gears and equipped with a pulley drive on side. Tricylcle wheels. Needs a gas tank. It was removed to be repaired and later lost. Need to know more about model to locate. Anybody got any ideas?
Jerrie Lott
06-22-1999 16:00:55
 Re: Case identification #'s? in reply to Mike Watson, 06-02-1999 07:47:40
Mike Does it have cast iron front tires or steel, does it have a cast iron radiator grill or steel, does the hood open in the front like a car or is the hood bolted on pemantly, does it have a steering arm along side of the hood or a shaft along the engine block to a steering box in front. As far as I know they made "SC,s" and "DC,s" until 1955 and "VAC,s" until 1956. Both SC and DC had a belt pulley as standard equipment. the VAC was made with or without and if you fid the ID tag it will say on there what model it is and the year is coded in the serial #, You have subtract a number from certain numbers in the serial number but I can't remember the exact formula. Hope this is of some help. Jerrie Lott
H. L.
06-03-1999 04:33:10
The original ID information was on a tag on the Dash under it gauges. a better description or a picture would help. The information you gave the make up of a VAC or any number of tractors.
