1410 David Brown ? for Elmer
cj
12-04-2003 16:33:09
Elmer,
I am in the process of restoring a 1410 David Brown. You have helped me with other questions on this tractor and I appreicate the advice. We have a sleeve kit for this tractor. What or how is the best way to remove the sleeves out of the block??? I have had other people tell me the 1410 does not have sleeves in the block. But I can see the old ones in there and they are scarred.
thanks again for the help
CJ
Elmer
12-05-2003 04:30:04
 Re: 1410 David Brown ? for Elmer in reply to cj, 12-04-2003 16:33:09
There are no sleeves in the block. They are parent bore. They can be fitted with dry sleeves. If you have sleeves that is what they are. A machine shop has to bore out the block and install them. Where did you get the sleeves?
cj
12-05-2003 05:04:46
 Re: Re: 1410 David Brown ? for Elmer in reply to Elmer, 12-05-2003 04:30:04
I got the sleeves from "Bare-Co"....
I saw u left a phone number on a previous post for someone else. If it is ok I will give u a call. I have other questions also.
Thanks again
cj
