intersting stuff on cast iron welding
INCase
12-04-2003 13:09:37
FYI>...
found this web page thought a few of yous may be interested Link a bit high $$ though... $8/rod. claims to weld anything even castiron manifolds...
MGM
12-08-2003 04:08:56
 Re: intersting stuff on cast iron welding in reply to INCase, 12-04-2003 13:09:37
My experience with Cast Iron welding is that is should be preheated with a torch to a prescribed degrees and then welded, The big part is to stand around and listen for a loud ping, cast likes to crack on cool down and not in the place you just welded, Just my 2 cents worth
MGM
ChadS
12-06-2003 07:58:57
Got one better than that,, they make a wire that you can put in a MIG welder,, use argon gas and go welding,, it is the same weld as the nickle rods and a fraction of the cost ChadS
Slowpoke
12-06-2003 20:52:32
 Re: Re: intersting stuff on cast iron welding in reply to ChadS, 12-06-2003 07:58:57
And who might "they" be?
