Horspower for Case 930 CK
James
06-02-1999 05:46:14
Does anyone know the horspower, db and PTO, for a 1965 Case 930 CK - LP power?
Ron
06-02-1999 06:34:09
 Re: Horspower for Case 930 CK in reply to James, 06-02-1999 05:46:14
I remember reading in one of my tractor books that the diesel version has 91 HP so I expect the LP would be very close.
James
06-04-1999 05:57:18
 Re: Re: Horspower for Case 930 CK in reply to Ron, 06-02-1999 06:34:09
Thanks Ron. I thought it was about 95 hp. Do you recall anything on the PTO hp? Is there any rule of thumb associated with PTO hp, like approximately 60% of the db hp?
Ron
06-08-1999 06:06:05
 Re: Re: Re: Horspower for Case 930 CK in reply to James, 06-04-1999 05:57:18
James, Sorry but I made a mistake on my earlier message to you. The 930 Case has 71.92 drawbar HP and 80.65 PTO HP as recorded in the book by Lester Larson. That's at 1600 RPM on the 401 cu. in. 6 cylinder engine.
Ron
06-07-1999 08:04:30
Typically PTO HP is greater than drawbar HP. I would expect the "rule of thumb" to be different for different tractors, but I'm not knowledgeable of such details.
MADDOG
04-01-2004 10:16:46
 Re: Re: Re: Re: Horspower for Case 930 CK in reply to Ron, 06-07-1999 08:04:30
No, that's not correct; the "rule of thumb" is
the SAME for all tractors, crawlers, dozers; I've
done Hundreds of PTO Horsepower runs on Calibrated PTO dynamometers. There should BE ONLY ONE tractor HP measurement; and that is PTO Horsepower. PTO HP is the ONLY value that can be DIRECTLY measured with calibrated instrumentation;
ALL the other HP values are MATHEMATICALLY-Derived
by us engineers; I've done thousands of the calcs...By using "Belt HP", "Drawbar HP" and other BS figures; this allowed different Tractor manufacturers to "fudge" the HP figures. However, MANY tractors DO NOT HAVE PTOs; most crawlers and dozers DO NOT have PTOs, that's how the "Drawbar" and "belt" HP figures came into being. Concentrate on the tractor's PTO figure; it's very easy to "fine-tune" a gas or diesel tractor while the equipment is still hooked up to the dyno. As a matter of fact, it's the ONLY WAY a newly (Tractor-engine) overhaul should be set up AND Broken in. Then when the owner/operator puts the tractor out in the field, under load, he can be assured that the new-engine is ready to go....Yes, I realize it can take a few hours with a tractor under full load, to fully set the rings, etc.
