SI Airborne CASE Project
WTW SI Case Air
12-03-2003 14:11:23
Getting closer to the end of my 1944 SI Airborne tractor restoration project and need some help. First I need to know where a person can find a water pump seal and bearing for this Case engine. Second, where can one get replacement brake lining disk for the brakes? Third what is the paint number for OD green used back in 1944? I tried to email Mr. Smoker but have an old email address and could not reach him. If you or anyone else out there can help please do, any information you can share would be very much appreciated. Thank You, Dave W.
D Smoker
12-07-2003 09:34:03
 Re: SI Airborne CASE Project in reply to WTW SI Case Airborne, 12-03-2003 14:11:23
Dave
You can get brake lining from a Case dealer, if you need the part no. let me know. The water pump stuff you can get from one of the people on this board.
There are a couple of variations on the paint and paint codes. If you want to email me I can explain them to you. If you email your phone no. that would help. I tried to email you here it kicked back.
ff316
12-03-2003 19:58:57
Maybe someone at the military vehicle preservation assoc. can help with the paint code. Go to mvpa.org and look around. Good luck, post a picture when it's done.
Fireman in KY
Brandon
12-03-2003 19:10:52
For help on the Olive Drab color, I suggest going to:
Link
That is a modelling website, but the discussion forums (you could probably try the "Tank Talk" board) there are full of knowledgeable and helpful people, and I'm sure they can get you a paint code, or source to get it.
Good luck!
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
Dave
12-03-2003 18:20:38
Hey,
Use Don L. at rusty acres I believe its [email protected] his number is (507)433-0073. Call in the mornings. I got brake linings and rivits, he also has everything else you will need. If he doesn't have it he'll guide you on where to get it.
Dave
John Saeli
12-03-2003 16:38:36
Hey Men; I have CASE seal kits for those water pumps.
Baggsy-Wy
12-03-2003 15:23:58
I had zero luck finding replacement parts for my SI waterpump, just go thru Don L. and get a new one. Brakes can be had thru Case, but you need somebody who knows how to look 'em up in a book and not a computer. Darrell Smoker was the formost expert on them, but hasn't been out here in quite awhile. He used to show up on Tractor Tales board now and then...
