latch 51 VAC
Kent
12-03-2003 13:35:03
third party image
i am trying to find the mate for this - i think the casting number should be vt 614 - it fits on the eagle hitch - case dealer says no longer available
Joe (Wa)
12-03-2003 15:32:58
 Re: latch 51 VAC in reply to Kent, 12-03-2003 13:35:03
Kent, If that one is vt615, the one for the RH side is vt614...a28941 appears to be a good cross-ref nr. Joe
Joe (Wa)
12-04-2003 15:31:40
 Re: Re: Re: latch 51 VAC in reply to kent, 12-04-2003 04:57:13
There are two different latch shapes for the vt579 claw.
RH latch vt614 is rounded on the back vertical side where it mates up with the back of the claw (per your pix of LH vt615).
RH latch vt580 ... a28926 is straight here lying almost flat against the back of the claw and the nose is slightly different. I think this is the earlier style.
You will probably have to hunt the salvage yards.
Good luck, Joe
kent
12-05-2003 09:17:19
 Re: Re: Re: Re: latch 51 VAC in reply to Joe (Wa), 12-04-2003 15:31:40
hey thats great to know - will the vt 580 work functionally with my hitch while hunt for a 614?
Joe (Wa)
12-05-2003 13:38:17
 Re: Re: Re: Re: Re: latch 51 VAC in reply to kent, 12-05-2003 09:17:19
The hitch should have the vt579 claw on both draft arms.
From the Case parts manual the latches can be either:
vt580 right side and vt597 left side
OR
vt614 right side and vt615 left side
I don't see any reason they cannot be mixed unless you just want a matched set.
kent
12-08-2003 08:25:53
 Re: Re: Re: Re: Re: Re: latch 51 VAC in reply to Joe (Wa), 12-05-2003 13:38:17
Thanks a ton - ill order some replacements and give it a try - right now im after functional -
kent
