VA Wheel won't stay put
Ross
12-02-2003 19:19:05
Am I the only one who can't get their rear wheels on their VA/ VAC's to stay put? I think the PO must have gotten the teeth on the hub connecter wrong and spun the hub and wore the teeth down too much. Does anyone know if new hub connector are available new. I know that's terribly unlikely but I'm afraid any used ones I find won't be any better than what I have. Can I build the teeth up? And is there a trick to getting them to stay put?
Thanks Ross
Rigidharley
12-10-2003 08:52:21
 Re: VA Wheel won't stay put in reply to Ross, 12-02-2003 19:19:05
Hello, what are you referring to as the hub? most va's have a 5 spoke spider(hub), thatis attached to the the axle by means of a clamping device and a key set in the keyway to keep it from spinning on the axle. Jim
