811B Hydraulic Filter
David811B
12-02-2003 11:31:21
The napa near me says they have a filter #1475 that works for it. Does that ring a bell with anyone? My original filter was damaged by freezing water possibly. has a big crack in it and there was lots of water in there. it had settled at the bottom. The case # in my manual says 08755AB. Napa has to get it from wherehouse so I cant compare yet. Would it be better to drive to next town (15 min.) to Case dealer??
caseman-d
12-02-2003 11:44:29
 Re: 811B Hydraulic Filter in reply to David811B, 12-02-2003 11:31:21
I beleive the number for the hydraulic filter is right in the book but the convertor filter is wrong.I show O8755AB for the hydraulic, convertor filter is shorter and is not right in most parts books I have come across. Almost bet the Case is cheaper than the Napa filter.
caseman-d
Larry Calhoun
12-03-2004 18:09:29
 Re: Re: 811B Hydraulic Filter in reply to caseman-d, 12-02-2003 11:44:29
Need some help please. I"m looking at buying a Case 811B. It will pull in the lower range gears but will not spin a tire. It will not pull at all in the higher range gears. Any idea of what the problem could be and a possible fix? I would appreciate any ideas.
david811b
12-02-2003 13:29:07
Now another dealer says A27460?
caseman-d
12-02-2003 20:51:05
 Re: Re: Re: 811B Hydraulic Filter in reply to david811b, 12-02-2003 13:29:07
the A27460 if the number for the convertor. Its shorter than the hydraulic filter.
caseman-d
David811B
12-02-2003 12:38:06
Just called the case dealer, they say they don't have that # they said it was a A42242 which I think by description is the power steering filter. My original filter looks like a reusable one but it is damaged looks like water was in it and expanded. PTO housing had water in it up to filter. I remember when parts people had to have a clue.-David
turbo
12-02-2003 17:23:26
 Re: Re: Re: 811B Hydraulic Filter in reply to David811B, 12-02-2003 12:38:06
O8755AB hydraulic filter subs to A27460.
A11552 is the converter filter.
A42242 is the power steering filter.
