Need help identifying distributor on 930 Lp
PoppinJohn720
12-01-2003 20:01:02
Im trying to identify the distributor on a 69 model 930 Lp. I cant find any tags or markings anyplace. Is it a prestolite??? I want to convert it to electronic ignition. Will this conversion be possible without a bunch of butchering? Thanks in advance!
Glen in TX
12-02-2003 14:22:07
 Re: Need help identifying distributor on 930 Lp in reply to PoppinJohn720, 12-01-2003 20:01:02
Okay, the Prestolite book I have showed another dist. for the 930 LP also. It is a Prestolite IBT-4402A or 44-520 and the complete unit was discontinued but some parts are still available. The Pertronix catalog shows using a #1562 Ignitor or #91541 Ignitor II kits for this. For best results you will want to upgrade to the hotter coils also and perhaps a new set of wires. I'm sure you could fit this kit into the Wico DB dist. also. If you need help finding the kit let me know.
Glen in TX
12-02-2003 12:55:56
Your distributor is a Wico DB-2648, X30164. My Wico DB parts list shows this distributor to fit the JI Case 940 (930) tractor with A377 LP engine 1600 RPM and to also fit A377 power units. I still have a few parts for the DB distributor and some are still available new but many parts for this distributor were discontinued long ago. I am not sure if a later Prestolite replacement was used but will check to see in other books. May not be a elec. kit listed for this one but that doesn't mean it can't be done. Something can be made to fit it. If you are needing other parts for it too let me know and can advise if available.
David811B
12-01-2003 20:11:55
Do your Deere buddies know youre hangin out here LOL. I know a pertronix kit is super simple to put in. Zero butchering
PoppinJohn720
12-01-2003 20:23:29
 Re: Re: Need help identifying distributor on 930 L in reply to David811B, 12-01-2003 20:11:55
I like all brands of old tractors. So take it easy on me. Im leaning towards a kit from Genessee Products because they are local. Any thoughts or comments on this? See yall!
david811b
12-01-2003 20:30:57
 Re: Re: Re: Need help identifying distributor on 9 in reply to PoppinJohn720, 12-01-2003 20:23:29
I was just teasing you!! I would own a deere if I could afford it. Prices too high in Arizona everyone wants one
