VAC wiring
Lucas
12-01-2003 19:54:25
If I have my VAC wired on negative ground, what happens when I switch it back to positive like it should be. Will I have to change anything else? Thanks
GeoMo
12-03-2003 05:18:46
 Re: VAC wiring in reply to Lucas, 12-01-2003 19:54:25
If you really want to change it back to org.
After you change wiring you will need to polarize the generator.
curtis
12-02-2003 20:54:12
i have a 49 vac and i just started over with the delco alt and put a reis at the coil wired on neg ground and away we go !
