oil in water
Gordon
12-01-2003 14:49:24
Any ideas how oil gets get in the water, It doesn't have a oil cooler that i know of. in a 600 diesel?
Not very much just a little keeps showing up. Thank you Gordon
JRT
12-01-2003 17:20:37
 Re: oil in water in reply to Gordon, 12-01-2003 14:49:24
Also there is a possibility you may have a small leak in your head gasket. My 400 did that and I had to put on a new head gasket. That fixed the problem.
John Saeli
12-01-2003 15:51:05
Hey Gordon; If you don't have any indication of blow-by into the radiator, then your lucky. Sounds like a leaky "O" Ring at the bottom of the sleeve. I've cured that problem with radiator seal. I had good luck with Bars Leaks. Hope this helps.
