SC Water Pump
C. Amick
12-01-2003 14:15:38
I put a rebuilt water pump on the SC and it didn't want to pump and the tractor got hot. I then took it off, flushed the system out, and put an old one on and it pumps fine (except it leaks). Could the rebuilder have done something wrong? If the water pump is not faulty, the only other thing I could think of was that there may have been some rust in the system blocking the flow of coolant.
Mike Schotte
12-01-2003 15:03:40
 Re: SC Water Pump in reply to C. Amick, 12-01-2003 14:15:38
Myron,
I know that you've probably already checked this... but is it possible that the thermostat was in backwards or that copper bypass tube on the waterpump was obstructed?
-Schotte
