SC Transmission oil
Randy
12-01-2003 12:58:35
I am getting ready to change the 11 gallons of transmission oil on my 49 SC for the first time. When you open the drain does it pour out fast?
I don�t have a container that will hold all 11 gallons. Can I get the plug back in after a few gallons?
Thanks
Randy
voice of experience
12-01-2003 16:43:00
 Re: SC Transmission oil in reply to Randy, 12-01-2003 12:58:35
It is a mess! Do it on gravel on concrete where oil stains will not matter. Get three five gallon buckets under the tractor and ready to move under the plug. Another pair of hands is helpful. I put 85W140 in mine and it really quieted down and the little bit of seal leaks that I had dried up - Todd Hamilton
RandyD
12-01-2003 18:32:21
 Re: Re: SC Transmission oil in reply to voice of experience, 12-01-2003 16:43:00
I do have a leak at the belt pully and a bit of noise.
Randy
todd hamilton
12-02-2003 06:44:39
 Re: Re: Re: SC Transmission oil in reply to RandyD, 12-01-2003 18:32:21
That's where my leak was too. I think that it is water in the old oil. That shaft is mounted pretty high in the transmission case. I think the heavier oil settled to the bottom. Same theory on the noise. I also flushed mine with kerosene before I put the new oil in. Be prepared for 20 gallons of waste oil if you do this step. I know a dump-truck repair shop that uses a waste oil furnace for heat. They were glad to take it.
RandyD
12-02-2003 06:49:31
 Re: Re: Re: Re: SC Transmission oil in reply to todd hamilton, 12-02-2003 06:44:39
Todd, did that clear up the noise and leak?
Randy
Glenn FitzGerald
12-01-2003 14:26:03
It pours as fast as #90 transmission oil can pour! You should have room for a 5 gallon pail. That should allow enough time to get the plug back in. Simple job. G.F.
Randy
12-01-2003 15:24:34
 Re: Re: SC Transmission oil in reply to Glenn FitzGerald, 12-01-2003 14:26:03
Thanks Glenn for the feedback. It just seemed like a mess getting ready to happen.
Randy
