SC timing
Tony
12-01-2003 11:14:17
I picked up a non running SC recently. This is my first SC and I have a self inflicted problem with the ignition system. While compiling a list of parts needing replacement I pulled the distributor cap assembly. Then I messed with the fiber gear that drives the rotor. Only after giving it a few spins did I realize that there was no way to relocate it to the original position. Then I saw a sticker in the bottom of the cap that says something to the effect "find the mark on the gear and line it up with a certain tooth on the small steel gear it meshes with" That's all fine but somewhere in this tractors life the points had been replaced and the screw that holds the points in position had a larger head than the original and it rubbed off the mark that I need on the fiber gear. Any suggestions?
Mike Schotte
12-01-2003 11:58:04
 Re: SC timing in reply to Tony, 12-01-2003 11:14:17
It's hard to see (and I think they are on the side you don't normally look at) but there are two beveled teeth on the fiber rotor gear that align with the dot on the steel gear.
-Schotte
