SC Valve Cover Gasket - Case/IH Part Number?
C. Amick
12-01-2003 09:45:37
Do you know what the Case/IH part number is for the valve cover gasket? NAPA says they have none in their warehouse. I can order a whole head set, but really only need the valve cover gasket.
Home at last...
12-01-2003 17:07:35
 Re: SC Valve Cover Gasket - Case/IH Part Number? in reply to C. Amick, 12-01-2003 09:45:37
O.K. Myron, it's me again:
I was able to pick up a valve cover gasket for my Case SC off the shelf at my local parts dealer:
Fel-Pro #VS 6921 Valve Cover set containing (1) C 6921 Valve Cover gasket. (The application listed on the package is for a Case SE engine... but we all know they are the same)
The Case part number from my book is:
#O5764AB - Gasket, cylinder head cover
#O5766AB - Gasket, breather tube elbow
Hope this helps, -Schotte
Morris L. Glaser
10-28-2005 11:20:22
 Re: Re: SC Valve Cover Gasket - Case/IH Part Numbe in reply to Home at last..., 12-01-2003 17:07:35
What is the cost including shipping for valve cover gasket for 1951 Farmall C?
Mike Schotte
12-02-2003 13:32:08
Just for kicks- I called my local NAPA store to see if they had one.
They said they don't carry Fel-Pro, but the Victor part number for the equivalent Case SC valve cover gasket is #VS 38079.
They didn't have it in stock- would have to order it from Oak Grove.
-Schotte
turbo
12-01-2003 12:30:31
O5764AB Gasket cylinder head cover
Mike Schotte
12-01-2003 09:51:54
I bought mine at a local parts store (not NAPA, for once.)
I saved the box, and can look it up for you when I get home tonight.
I'll also give you the Case number, if somebody doesn't give it to you before I get there.
-Schotte
