case 1070 won't move
Jason
11-30-2003 18:49:43
Push in the clutch and it doesn't do anything.Can put it in any gear without using clutch.I pushed the clutch in and out several times thought maybe a valve was stuck or something,well it worked one more time.Drove it across the barn lot shifted up to third shifted back to first and pushed in the clutch when i let out it wouldn't move.Neighbor had used and blew a hydraulic line on an implement he was pulling.It was 10 gal low when i went to get it.I filled it before i took it home but i don't know how long he ran it that low on oil.Any info would be appreciated.
Jason
Jim Handke
11-30-2003 19:14:56
 Re: case 1070 won't move in reply to Jason, 11-30-2003 18:49:43
When the torque limiter goes out, it will not move. If you remove the floor plate in the cab, remove the bolt on the linkage that moves the powershift back to low when you dspress the inching pedal. Now you can shift the powershift up to the high side and it will stay there. If the tractor moves when you release the inching pedal(clutch), C-1 clutch is out. If the tractor moves in reverse, C-2 and C-4 clutches are good, so C-3 would be out. Check transmission pressure guage. If the pump went bad, the guage will show low, or no pressure, and the tractor will not move either. I didn't hide my e-mail address, contact me if you have any questions.
