38 or 39 DC or DH Case
Larz
11-29-2003 18:10:12
I have 2 DC's and an old neighbor gave me a tractor for parts that has been in the back corner of his shed for at least 40 years. He says it's a 38 or 39 DC that you sit higher up than the usual DC. Is this a DH, and is it worth restoring. Are most parts interchangable with a "regular" DC, is it worth anything when I'm done.
robert
11-30-2003 04:59:19
 Re: 38 or 39 DC or DH Case in reply to Larz, 11-29-2003 18:10:12
A 39 D had tall rubber clam fenders,a hand park brake and a generator between the mag and govener housing .Could it not be an early standard "D".I'm sure I read and seen pictures of these.Would be so much better plowing as draw bar is tooo low on a standard D if a soft spot is found!!
dctom
11-29-2003 18:52:42
look in the tractor photos on this site and you can see my DH, i would doubt very much if yours is one send me the sr# and i will let you know, it cant be a 38 as there was no such thing as a 38 DC
dctom
11-29-2003 18:51:55
look in the tractor photos on this site and you can see my DH, i would doubt very much if yours is one send me the sr# and i will let you know, it cant be a 38 as there was no such think as a 38 DC
CASEPOWER
11-29-2003 18:17:43
It could be a DCS high clearance. If so keep it and restore it instead of the DC cause it's rarer and worth MUCH more..
Larz
11-29-2003 18:29:24
 Re: Re: 38 or 39 DC or DH Case in reply to CASEPOWER, 11-29-2003 18:17:43
whats the differance between a DCS and a DH???
CASEPOWER
11-29-2003 18:32:36
 Re: Re: Re: 38 or 39 DC or DH Case in reply to Larz, 11-29-2003 18:29:24
DCS will have drop housings on the end of the axles for the bull gears.
Larz
11-29-2003 18:35:39
 Re: Re: Re: Re: 38 or 39 DC or DH Case in reply to CASEPOWER, 11-29-2003 18:32:36
Nope.... straight ax ..not like a wd Allis
CASEPOWER
11-29-2003 18:49:31
 Re: Re: Re: Re: Re: 38 or 39 DC or DH Case in reply to Larz, 11-29-2003 18:35:39
The difference between a DC-4 and a DH is that a DH does not have turning brakes. Does it have two brake pedals??
Larz
11-29-2003 18:56:36
 Re: Re: Re: Re: Re: Re: 38 or 39 DC or DH Case in reply to CASEPOWER, 11-29-2003 18:49:31
I didn't look ... sorry
