La Case
walter
11-29-2003 15:56:37
Looking for a set of LA wheel weights, does anybody know what they weigh?
Also looking for an LA steering wheel.
Steve
11-29-2003 20:33:47
 Re: La Case in reply to walter, 11-29-2003 15:56:37
Just an FYI. The LA steering wheel has 4 spokes. The others have 3. Not sure if they are the same dia either. If the LA is bigger you will definitely want the leverage. Wish mine was about 4 feet in dia sometimes:)
Jim P
11-30-2003 22:09:29
 Re: Re: La Case in reply to Steve, 11-29-2003 20:33:47
La's from first through 1947 had three spoke steering wheels , 48 through end were 4 spoke
caseman-d
11-29-2003 16:25:23
Depending which weight you go with, must of the smaller ones weigh 150lbs, if you have a later model LA you should be able to use Case 500,600 heavy weights that weigh in at 640lbs or the 705lb weight. Steering wheel should interchange with most case tractors. Hope this helps.
caseman-d
