Power lift problem
Homer Barrera
05-31-1999 08:42:18
I have a problem with my power lift on my tractor, it won't go down. It is a case model 1570 It is a 1976(year). Does any one know what is wrong with it???
Don
06-01-1999 09:12:20
 Re: power lift problem in reply to Homer Barrera, 05-31-1999 08:42:18
Homer,
The hitch valve is located on the bottom of the trans. housing on your tractor. The position and draft control cables run from the cab along the right side of the tractor and attach to levers on the draft control box. If you move the hitch control lever in the cab and the small lever on the draft control box (under the trans. housing) moves, then your problem is internal. Could be the internal linkage has come loose or one of the hitch control spools is stuck. One other possability is that the hitch was mechanicly raised too high and the connecting rod between the hitch piston and the rockshaft came out of it's socket and has wedged the hitch in the raised position. Hope this helps, good luck.
Don
06-01-1999 09:11:58
Homer,
don ruscha
05-31-1999 19:27:07
on my 1070 witch is alot like yours. there is a inspection plate in the platform in front of the seat witch is access to the hyd valve linkage. i had a pin come out or your controll cable may have broke witch you can see from the inspection plate if you look while you move the lever.
