If it ain't broke.....
Les...fortunate
11-29-2003 03:36:03
Since 10 weight oil does not seem to be available here, I put some "tractor oil" into my torque tube on the VAC. Now the Eagle hardly wants to lift off, say nothing about landing.
When will I ever learn not to mess with something that's already working fine?
Don't answer that.
Bob
11-29-2003 12:48:09
 Re: If it ain't broke..... in reply to Les...fortunate, 11-29-2003 03:36:03
If it ain't broke... FIX IT UNTIL IT IS!
Les
11-29-2003 13:36:37
 Re: Re: If it ain't broke..... in reply to Bob, 11-29-2003 12:48:09
Unfortunately, that seems to be my motto. :(
caseman-d
11-29-2003 08:02:43
Dependind how much you put in the engine oil may be causing the oil to foam, thats why it's slow. Might try draining it and refill with hy-tran from your Case/Newholland Dealer
caseman-d
Les...fortunate
11-29-2003 13:35:39
 Re: Re: If it ain't broke..... in reply to caseman-d, 11-29-2003 08:02:43
I doubt that is the case. The tractor had been sitting for a couple hours and I had just started it up so it was not hot at all.
