DC Case Eagle Hitch / top link ----- I'm Looking
Glenn F. / Flam
11-27-2003 18:38:24
Currently have a home made bracket and modified top link. Would really like to have the real thing. Expensive? Hard to find? Anayne have? Let me know. Santa's sleigh will be loadede with cast iron this year. Glenn
Rc
11-27-2003 20:52:15
 Re: DC Case Eagle Hitch / top link ----- I'm Loo in reply to Glenn F. / Flambeau'54, 11-27-2003 18:38:24
Glen could you post a picture or explain how you did it I have a idea but dont know if it will work or not. thanks Rc
Glenn FitzGerald
11-29-2003 20:52:55
 Re: Re: DC Case Eagle Hitch / top link ----- I'm in reply to Rc, 11-27-2003 20:52:15
Rc, the bracket is quite simple. It took a little experimenting to get just right. If I were starting over it would be a little cleaner. I'll attempt to describe it. If unsuccessful I'll try posting a picture. Bracket is constructed of 1/2" steel and 2" OD pipe. 5 1/2 " square plate with 9/16" holes bored in each corner on 4 1/2 centers. 1 3/4" hole drilled in center for PTO shaft. 2" OD pipe 3" long (with a thin cap welded over end) welded over hole enclosing PTO. Two 2 x 4 1/2" flat stock (1/2" stock) welded perpindicular to the 5" square plate 1 3/4" apart to accomodate top link. 3/4" holes 3/4" in for pin to go through. Flat stock welded to 2" OD pipe to add strengh. Works perfectly. Buzz me back if unclear. Glenn F.
