fast idle 430 gas
gaetan
11-27-2003 18:34:33
my 430 case have very fast idle look like
its in the governor have to pull on the governor rod and hold it to slow her down
any idea what could it be thank you gaetan
Dennis/Ohio
11-30-2003 01:46:06
 Re: fast idle 430 gas in reply to gaetan, 11-27-2003 18:34:33
Hello, Governors are basic. Your push lawn mower governor works the same as your tractor. The fly-weights in the governor are trying to keep the engine at an idle. The had throttle spring is trying to over come that force and speed the engine up. Adjustment: hand throttle full throttle, carb wide open. adjust carb rod to fit freely in the hole on the carb lever. I think understanding how it works will be the way you can find the problem.
Hope that helps, Dennis.....
JohnM
11-27-2003 18:39:06
Have you checked to see if either something is hitting against it or the spring got damaged?
