VAC lubes
Pat
11-26-2003 10:03:55
I'm restoring a 52 vac and I'm curious what fluids to put in the gear box and rear.
mj
11-28-2003 12:03:30
 Re: VAC lubes in reply to Pat, 11-26-2003 10:03:55
The trans-axle takes GL-90. If you are doing a drain and refill and live where temps are below freezing for a good part of the year I'd suggest using GL 80-90W. The torque tube (section between the trans-axle and bellhousing) on Eagle hitch tractors takes SAE 5-W below 32 deg. F, SAE 10W between 32 and 60 degrees and 20W for temps. above 6O. I just run 20W year around with temps ranging from below zero to 90+. :-)
