Electrolysis picture
F-I-T
11-26-2003 07:55:43
third party image
Just wanted to encourage anyone that has any greasy, rusty, or paint-layered tractor parts to take advantage of the long weekend and set up an electrolysis tank.
These parts were in the tank for 15 hours, then a blast from the power washer. No matter how often I use this process, it never fails to amaze me.
I have the recipe on my website if anyone is interested.
Happy Thanksgiving!
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
John Saeli
11-26-2003 18:17:44
 Re: Electrolysis picture in reply to F-I-T, 11-26-2003 07:55:43
Alright Men, I admit to not being very bright, so no beating around the bush. How do you set up an electrolisis?? BTW Happy Thanksgiving to all!!
F-I-T
11-26-2003 19:26:46
 Re: Re: Electrolysis picture in reply to John Saeli, 11-26-2003 18:17:44
John:
I'll give the nickel description, and then you can read the full length paper that I have on my website if you need more.
Electrolysis as we discuss it here, is an electrochemical "Cell". The electrolyte is either Sodium Hydroxide (Lye or Caustic soda) or Sodium Carbonate (Soda Ash or Washing Soda).
You take a plastic bucket, tub, vat, or swimming pool, and fill it with a solution of 1 tablespoon per gallon of electrolyte. Then you hang a piece of scrap iron or steel in the tub, and hang the part you want to clean in the tub so they do not touch. Take a 12 volt battery charger and hook the red lead to the scrap electrode, and the black lead to the part. When you turn on the power, the part will slowly begin to give off very small bubbles as will the scrap metal electrode. This is Hydrogen and Oxygen being gassed off. These bubbles will get under everything on the surface of the part and lift old oil, grease, paint, chewing gum, Permatex, etc. The electrochemical action will convert Red Rust to an inert form, Black Oxide, that is paintable and primable, or easily removed with a pressure washer or a plastic pot scrubber.
don't hook the leads up backwards or you will "rust " your part and it will dissolve over time. But, if it's hooked up right, as long as the power is on, you can let the parts in the bath for as long as you want, and the part will not change size in any way. It will only loose it's red rust, dirt and paint.
After cleaning, I usually power wash, rinse, and allow to dry, Then I apply my favorite primer, and the part is chemically rust free.
That's about it.
I published an article on the process a while back, and it's on my website under "Restoration Tips".
70D // 855 // VAC
[email protected]
John Saeli
11-27-2003 07:38:14
 Re: Re: Re: Electrolysis picture in reply to F-I-T, 11-26-2003 19:26:46
Hey F.I.T. Appreciate that. Gonna give it a try.
Klyde
11-26-2003 10:37:56
I don;t dare do it ! I remember puttimg a carter spread bore 4barrel carb to soak in the carb cleaner on a friday(was going to take it out before going home) Moday noon I remembered it, all that was left was safts jets and some hardware. O well I wanted a new carb anyway.
todd hamilton
11-26-2003 14:15:08
 Re: Re: Electrolysis picture in reply to Klyde, 11-26-2003 10:37:56
It's O.K. - Zenith carbs are a lot better built than those junk Carters! (GRIN) :^)
todd hamilton
11-26-2003 14:12:09
Zenith carbs are a lot better built than those Carters (GRIN) :)
Mike Schotte
11-26-2003 10:01:46
Happy Thanksgiving, Frank!
I'll second your motion... electrolysis is pretty great. Baggsy is the one who got me started on using it.
FROM THIS:
third party image
TO THIS:
third party image
in three days.
-Schotte
todd hamilton
11-26-2003 14:09:09
 Re: Re: Electrolysis picture in reply to Mike Schotte, 11-26-2003 10:01:46
That's great! It looks like it even cleans and improves carpet. A remarkable process. (GRIN) :^)
Mike Schotte
11-26-2003 14:11:08
 Re: Re: Re: Electrolysis picture in reply to todd hamilton, 11-26-2003 14:09:09
HAH! That's funny.
I have an old carpet outside where I park my tractor to keep the weeds from growing.
That OTHER tractor is inside at my work (home of the digital camera.)
Thanks for the laugh! -Schotte
F-I-T
11-26-2003 10:28:28
Mike:
So in three days, it grew a carbruetor....maybe in a week it'll grow a new air cleaner!
Ha! ;>)
Slowpoke
11-27-2003 23:23:07
 Re: Re: Re: Electrolysis picture in reply to F-I-T, 11-26-2003 10:28:28
But it ate away the sheet metal support bracket!!!
