Case CC Head
11-25-2003 15:35:00
Does anyone have the proper procedure for reinstallation of a Case CC head? What bolt tork? What's the tightning pattern? Any lube? Temprature issues? Also what's the proper spark plug and gap.
Thanks, Jack
Dave in GA
11-26-2003 04:17:24
 Re: Case CC Head in reply to [email protected], 11-25-2003 15:35:00
I'm using Autolite 3077 plugs gapped at .020 with good results.
RoyG
11-25-2003 17:19:14
Pulling a CC and A C and have A CC parade tractor
have found that Autolite plugs work the best.
Tom Railsback
11-25-2003 15:42:21
Work out from the center in a circular pattern; torque the bolts to 75 ft lbs and retorque after
about 1 hour of running time. Valves should be set to .018.
Spark Plugs: AC 85 or equivalent--.030.
