another foot throttle question?
david811B
11-24-2003 20:41:44
seeing the other posts it makes me wonder why did the 800Bs have or not have a foot throttle? Can it be retrofitted with the right parts? with the COM do you have it on the left or right?-David
caseman-d
11-25-2003 11:20:25
 Re: another foot throttle question? in reply to david811B, 11-24-2003 20:41:44
I beleive the 1958 800 had the foot throttle on the right side and in 1959 they had it on both sides.
caseman-d
Slowpoke
11-28-2003 00:41:28
 Re: Re: another foot throttle question? in reply to caseman-d, 11-25-2003 11:20:25
I've noticed that "800" is used interchangeably with "800B". Are they not two different machines?
I have an 801B. How is it different from an 801?
Did they just increase the rated rpm and call it a new model?
I'm concerned that if I order parts for an 801B, I'll get parts for an 801.
BTW, my 801B has dual foot feed.
tbair
11-25-2003 18:26:49
Makes sense caseman. Mine is a 58, it didn't look like the shaft had been cut or anything of that nature, that splains it.
tbair
11-25-2003 05:18:05
Steve,
My 811B has the foot throttle on the right side.
The parts manual I have shows only parts for pedals on both sides run off of a common shaft.
Mine appears to be original, If the shaft went
clear across to the left side the tool box would
have to be removed.
david811B
11-25-2003 07:06:07
 Re: Re: another foot throttle question? in reply to tbair, 11-25-2003 05:18:05
do you have the ability to email pics?? I would be interested in seeing how it mounts. Or where does the shaft run I can't figure it out.
[email protected]
tbair
11-25-2003 08:14:31
 Re: Re: Re: another foot throttle question? in reply to david811B, 11-25-2003 07:06:07
I'll see what I can do about the pics, I'll have to borrow a camera.
tbair
11-25-2003 05:27:09
Sorry David I don't know where I came up with
Steve.
