DC-4
jjw
11-24-2003 09:14:42
Just got the DC4 broke loose. Cylinder walls look good but was wondering if I flushed block out with kerosene and flushed out the entire cooling system will it be good enough to then put back together and see how it will run?? Got to much money in it already. thankx jjw
old
11-24-2003 10:37:22
 Re: DC-4 in reply to jjw, 11-24-2003 09:14:42
I've done that on a lot of engines, I also start them with no coolant in the system so they get a little hot, that helps brake the rings loose if they are stuck. Don't over heat it just let it get good and warm, with out the water in the system they cool slower so it brakes thing loose better. Hope this helps some
dctom
11-24-2003 11:40:52
 Re: Re: DC-4 in reply to old, 11-24-2003 10:37:22
goodness i thought iwas the only one that did that, run em with out water than re tork the head and put them on a dyno and pull thier guts out they will either be a good one or you will find out what needs to be done
old
11-24-2003 12:04:47
 Re: Re: Re: DC-4 in reply to dctom, 11-24-2003 11:40:52
Ya us old folks do some things that make the young people think where nuts, But as long as it works that is all I care about. I figure let them use all that new expensive stuff and I'll stick with my turpentine, vinegar and no water and just keep on fixing engines and not spending a lot of money on them either
jjw
11-24-2003 11:50:55
Is there something better than kerosene to flush this thing out with??? jjw
old
11-24-2003 12:01:27
 Re: Re: Re: Re: DC-4 in reply to jjw, 11-24-2003 11:50:55
I use turpentine it removes the rust and seems to soke in to all the places that oil doesn't seem to get to, But you need to use true turpentine not paint thinner etc. Turpentine in my area is hard to find but worth the hassele. I use it to brake loose stuck engines, I have one right now that I will be working on in the future and when I start working on it I'll fill the cylinders with turpentine. Right now they have oil in them just to keep them from rusting anymore then they have already
