DC head casting numbers?
Bob/wis
11-23-2003 19:07:55
I bought 2 DC today and was wondering if i could find out what heads are on them. The first number is 5576A and the other is on a LP tractor with a casting # of 5505A
Thank for your time.
Bob/Wis
Don Rudolph
11-24-2003 10:45:44
 Re: DC head casting numbers? in reply to Bob/wis, 11-23-2003 19:07:55
You might have a factory conversion kit on that LP tractor. The LP head (6128A)was optional and most people didn't spend the extra money for it. You may also have an aftermarket kit as there were several of those out.
Bob/wis
11-24-2003 04:31:35
Thanks alot for the info guys. You all been a great help
Bob/wis
dctom
11-23-2003 19:32:32
and 6128 is L P head ir yours dont have that in would be a field change over with out the head tom
DKase
11-23-2003 19:24:21
The 5576 head is the low compression head that was used with the all fuel manifold. The 5505 head is the common high compression gas head. I can't think of the propane head # right now, and the only other head used on the D series is the C head with the spark plugs that stick straight out that was used in the real early years. Hope this helps.
CASEPOWER
11-23-2003 19:20:42
5576A is low comp. all fuel head and 5505A is gas head.
