case 2670 PTO and hydraulics
mat smith
11-23-2003 07:10:47
we purchased a 2670 case 1975 model and for soem reason the PTO won't disengage it is always on no matter where the lever is and also the lift arms wont raise or lower any suggestions I am still looking for manuals too thanks
Tom
11-23-2003 16:08:24
 Re: case 2670 PTO and hydraulics in reply to mat smith, 11-23-2003 07:10:47
I had the same 2 problems when I bought my 2670. A bushing in the PTO unit was worn and did not allow the PTO brake to stop the output shaft from turning. It was an easy fix. As far as the 3-point, this is a common problem with this tractor. Alot of people have to push it down the first time with a loader. Mine didn't work that way. The top seal in the right 3-point cylinder had swollen so much that it wouldn't let the cylinder slide through. It looked as if water had gotten in it and the rust expanded out. Cleaned it up and a new seal and it worked great. I have a set of factory Case repair manuals for a 2670. Well over a 1000 pages, it is a must for this tractor. I would sell them if you are interested. E-mail me with any questions. Good luck!
JCmarleau
11-23-2003 10:30:00
If ever i do have many used parts for this model. my e mail is [email protected]
Jim Handke
11-23-2003 09:02:57
On ours,the cable broke at the power divider. The cable pulls the pto into the off position. We pulled the shaft forward and wired it to something to keep it from slipping back in. We've never had a problem with the 3 pt not lifting. Try depressing the inching pedal, and then moving the 3 pt lever to the up position. If this works, you have a massive leak in the powershift. At least, that how it works on the two wheel drives. Our 3 pt doesn't lower with no load on it. We use a loader to push it down, with the lever in the lower position. With a tool attached, it will lower just fine. Something is sticking in a cylinder, perhaps. Is your 3 pt. all the way down? If not, try our trick and then see if it will raise with the lever.
