I&T # C-202. Drain Rdiator and oil pan. On C-O-M models, disconnect the oil cooler hoses from the radiator and Case-O-Matic control cover. On models equipped with Hydrostatic steering, disconnect fluid lines as necessary, and cap all tubes and fittings to keep out dirt. On all models, remove the radiator. Remove the frame side rails from General Purpose models. On power steering models, disconnect the pressure and return lines. On models so equipped, disconnect the steering shaft at the U-joint, support the tractor under torque tube and unbolt the front support from engine assembly. On axle models, unbolt the radius rod pivot bracket. Roll the front wheels, front support and axle assembly forward and away from tractor. Disconnect the fuel line and throttle linkage, wiring harness, oil pressure line and heat indicator sending unit or wire. Unbolt and remove the starter, support fuel tank, and unbolt front tank bracket from engine. Swing the engine in a hoist and unbolt and remove engine from torque tube. That is what the book says.
