Tapping into main hyd line
Bob/wis
11-22-2003 15:45:19
I was thinking of tapping into the main supply line of a 930 case comfort king. Thought of useing a T where it comes off the pump and run it to another set of valves with a pressure regulate in them to run a loader.This would leave the 2 remotes for tillage work. Then run the return back to sump. Would this work. I know I owuld have to run one thing at a time because of no priotiy valve installed
Thanks
Bob/wis
11-22-2003 18:01:50
 Re: Tapping into main hyd line in reply to Bob/wis, 11-22-2003 15:45:19
DKase
Do you run the return from the valve back to the tractor valves to complete the circuit?
DKase
11-22-2003 22:00:49
 Re: Re: Tapping into main hyd line in reply to Bob/wis, 11-22-2003 18:01:50
I believe it would go to the 3 pt. hitch valve. Where ever the pump line went to in the first place. Good Luck
DKase
11-22-2003 16:04:24
Take the line from the pump out and have a hose made to fit in its place. Install your loader valve with a pressure relief in this line and you will have priority to your loader valve. The remotes will work just as they always did if your loader is not in use. I mounted a double valve like that on my 970 so I have 4 valves and it works GREAT. Mount a gresen valve under the platform and run the remote control cables up to a handy place in the cab. This keeps all the hoses out of the way and keeps the operaters station free from clutter. Good Luck
John Saeli
11-22-2003 16:57:02
 Re: Re: Tapping into main hyd line in reply to DKase, 11-22-2003 16:04:24
Hey D Kase; I want to run a hyd. pump off the PTO on my 730CK to add volume to speed up the loader. Where would I pull oil from, and will the remotes handle the extra volume? The loader & bucket is plugged into the remotes.
DKase
11-22-2003 17:34:00
 Re: Re: Re: Tapping into main hyd line in reply to John Saeli, 11-22-2003 16:57:02
WOW John looking to me for advice. I thought you were the official Case MD! If I was to put a PTO pump on for a loader, I would mount a seperate tank, valve, and filter. Would not want to risk contamination of tractor hyd. system. Good Luck
John Saeli
11-22-2003 18:30:03
 Re: Re: Re: Re: Tapping into main hyd line in reply to DKase, 11-22-2003 17:34:00
Hey D Kase,; Now, don't let that go to your head. Never gave contamination a thought. I wanted to assist the tractor hyd. system with a PTO pump to speed things up. The oils would mingle anyway. HhhMmm, have to give this more thought.
