580 b bachoe
robert
11-21-2003 23:41:10
Have 580b With 35 loader & hoe. The boom drops too fast.It is not the restrictor it is in right.
Also when you pull the boom all the way back to try to lock it, before it gets to the lock (it does not lock and the boom lever is still pulled) the dipper goes out on it's own. Any ideas?
Bob H nw Oh
11-23-2003 07:16:55
 Re: 580 b bachoe in reply to robert, 11-21-2003 23:41:10
Robert,I put answer to locking boom for transport on Tractor page,HTH,Bob.
Butch/ OH
11-22-2003 19:58:18
It sounds like you have an o-ring bad or missing on one of your load check valves that is under a circuit relief valve. I would look under crowd in circuit relief first. It's a little white o-ring and if it gets damaged it can cause all sorts of phantom movements in the backhoe. The boom dropping too fast might be a different problem.
