Mike Schotte, have you filled your Compressor...
Slowpoke
11-21-2003 23:14:12
yet? I saw your request for a valve to fill an air compressor at the gas station. Why not buy a 12v unit to run off the car/truck/tractor battery?
It will save trips to town, and is always there when needed. I use a "Truck Air" compressor, about $45 or less. It may not be as fast as a 120v compressor, but it can't be beat for a portable air supply. BTW, when I replaced my old battery, I got one with dual terminals. My vehicle uses side terminals, so now I have top posts for a 700W, DC to Ac power supply. I can run a drill, angle grinder, Sawzall and more anywhere I can drive.
ff316
11-24-2003 07:33:12
 Re: Mike Schotte, have you filled your Compressor. in reply to Slowpoke, 11-21-2003 23:14:12
Good ole boys around here convert their A/C compressors to air compressors for a true on-board system.
Fireman in KY
Mike Schotte
11-22-2003 04:07:56
Hi Slo-
Nope, I haven't bought that fitting. I need to go by Grainger and make the adapter.
Somebody on the Tool Talk board suggested that I might possibly mess up my compressor by running the air backwards through the pressure regulator. I've thought about that, too- but I don't know the answer. I can't install a tee between the compressor unit and the tank easily on this particular compressor design.
I've used the small battery powered compressors before- but they always seem like they are going to explode before they put out enough air to fill a 11X38 tire! Get pretty hot, too.
Where did you get your converter? I've always wanted one of the PTO drive generators... but those puppies are EXPENSIVE!
-Schotte
Slowpoke
11-22-2003 23:10:44
 Re: Re: Mike Schotte, have you filled your Compres in reply to Mike Schotte, 11-22-2003 04:07:56
The first compressor with which I had experience was a small one used to inflate a child's swimming pool. It got so hot it melted the case. Luckily, it wasn't mine!
My compressor has never gotten hot since it's fan cooled. It's supposed to run 8 hours nonstop to 275 max psi. Your 11x38 tire is only going to require 12-16psi. Even if it takes 15-20 minutes to work, you probably can't drive to the gas station, fill the compressor tank and return in that time. Mine is an AC Delco Truck Air. JC Whitney sells a similar one and so do some auto supply and others. Small DC-AC converters are available in lots of places. Got mine at Target, $42. It's a 400w-800w peak unit on which I ran a Sawzall and angle grinder with good results. That one now is used to run a tv-vcr, flourescent light and radio in a trailer. I've replaced it with a larger 700w-1400w peak unit for the tools, $70 total.
I think that size is obsolete and was replaced by the 750w-1500w peak converter. Try Home Depot, Lowes?, tool stores, catalogs, Ebay.
todd hamilton
11-22-2003 14:47:59
They also make gas powered air-compressors with lawnmower type engines on them. Someone as handy as you sould be able to take a junk lawn mower and an old air-compressor and rig something up. A horizontal shaft engine off an old elevator would work.
Glen in TX
11-22-2003 09:57:54
Hey Mike how about finding one of those PTO compressors or a sparkplug compressor hose? Kind of hard to mount a pulley on the new vehicles but on a older pickup we once had a extra pulley mounted on crank and a small compressor mounted to side of engine and just put a belt on it when we wanted air. Someone is making a nice 12V compressor and sells them at the farm shows. You could put that adapter in with a tee at the drain plug if yours has one.
