Carb adj. question for the experts
JohnM
11-21-2003 11:50:18
OK, so the 411B is all painted up pretty and I have been using it for a little field work (even with the paint job you HAVE to)and I am trying to get the carb just right. So I am adjusting the idle mixture screw out. The manual says it should be out 1 to 1 1/2 turns. If I go out more than 1/2 turn the motor wants to die. I replaced the screw, same problem. Seems to run best with the needle screw in tight! What is going on here? P.S looked in parts book and it does not show an O ring just the screw and spring so that is what I have on it.
Gene Dotson
11-21-2003 14:50:32
 Re: Carb adj. question for the experts in reply to JohnM, 11-21-2003 11:50:18
John; Sounds like you have a vacuum leak. Check carburetor mount gasket and intake manifold gaskets. The idle adjustment is an air bleed. Turning it in reduces the amount of air for idle mixture giving a richer mixture and turning it out makes the mixture leaner. With the tractor idling, take a propane torch and turn it on, but don't light it. Pass the open nozzle around all mating surfaces and see if it smooths out. That will be where air is being drawn into the intake system after the carburetor... Gene
Pat T
11-21-2003 15:54:30
 Re: Re: Carb adj. question for the experts in reply to Gene Dotson, 11-21-2003 14:50:32
Might be worth checking to see if the throttle shaft is worn in the carb housing, too. A little slop there will give you a nasty vacuum leak.
