Zenith Carb 9667 vs 11535
farmer_nk
11-21-2003 10:30:11
What are differences between the Zenith carb 9667 and the 11535. Both carbs are listed for the S series case tractor. the 9667, i assume was used on the 3.5 inch bore and 11535 was used on the 3 5/8 bore. Are there any other carbs, preferably larger, that will fit the S series? tia
Mike Schotte
11-21-2003 13:43:15
 Re: Zenith Carb 9667 vs 11535 in reply to farmer_nk, 11-21-2003 10:30:11
Your assumption on the Zenith carbs is correct.
I can't tell you what larger carbs would fit the SC- but I'm sure there are lots of applications that use that same size SAE mounting flange.
There is a Marvel-Schebler carb used on the SC that's an interchange for the Zenith 9667, but I'm pretty sure it's an equivalent design.
Hmmm... that makes me wonder: I've only ever seen the M-S carbs installed on the dual-fuel SC tractors... does anybody know whether they came on the gasoline only versions, too?
I wonder if they were just an alternate supplier- or if there's a difference in design due to the fuel type. Maybe DCTom or Don L. knows...
-Schotte
