What is the difference between TCH Hy Trans?
R Wyler
11-21-2003 09:58:01
I found a dealer fairly close to me the stocks TCH and I can get Hy Trans at a dealer that is closer. I am needing it for my 64 model 930. What is the difference in these oils? Thanks, R Wyler
turbo
11-21-2003 10:21:30
 Re: What is the difference between TCH Hy Trans? in reply to R Wyler, 11-21-2003 09:58:01
TCH
Transmissions Converters
Hydraulics
TCH has an anti foam additive for converters that you don't need in the 930
R Wyler
11-21-2003 11:41:59
 Re: Re: What is the difference between TCH Hy Tra in reply to turbo, 11-21-2003 10:21:30
Thanks Turbo for the information. Yes my old 6 speed 930 should use the Hy trans just fine. I was just curious. Thanks again. R Wyler
John Saeli
11-21-2003 15:37:37
 Re: Re: Re: What is the difference between TCH Hy in reply to R Wyler, 11-21-2003 11:41:59
Hey R. Wyler; Just my 2 cents worth; On my direct gear trannys where the hyd. system pulls from the tranny oil, I add 1/4 part 85W140. Hydraulics work great, except when the temp gets to the single digits, they are slow, but I like the extra body the 85W140 gives the oil when they are hot.
R Wyler
11-21-2003 15:47:40
 Re: Re: Re: Re: What is the difference between TCH in reply to John Saeli, 11-21-2003 15:37:37
Thanks John Saeli That does not sounds like a bad idea in the hot summer time around here. I know that hyd oil will become very thin in the heat. R Wyler
